Stickman21x
- Jul 28, 2019
- 9
First of, thank you for any input in advance. I'm first time boat owner. I picked up a 94 sea ray with 5.0 alpha.
When cruising 1/2 throttle, 20 mph or so (sorry forgot what the rpm was) it runs great. Open just over 3/4 or full throttle or 25 or so mph, it overheats in 10 mins.
It had not run for a year and was told the impeller was bad. I dropped the drive and changed the impeller, base plate and all o-rings. Went to check thermo and housing was heavily corroded. To the point the top ports were half the size. Replaced full housing including thermo.
Went out amd only had issue in upper throttle. Fastest way to cool it was open seat tops and what made a big difference was running engine only, at 1k rpm.
What would cause high throttle over heating?
Side question: what is a good cruising speed for 18 foot bow rider with 5.0 alpha? Didnt seem to be able to go over 30 mph on a flat lake.
Thank you again for any input!
