Re: Overcharging
Yep! It will charge at 16 volts but there is nothing to worry about. The charging system uses different windings on the stator and only affects battery, starter solenoid, choke, dashboard instruments and lights. 16 volts will not harm them.
The Stator has separate dedicated windings to power the ignition system. It is completely isolated from the charging system except for the common block ground. So, you need not worry about your CD box and coils. They won't blow out and leave you stranded.
In fact, the ignition system acts like a magneto ignition and contrary to a battery ignition where you stop power to the electronics to stop the engine, The ignition in your engine will continue to supply power (somewhere around 200 volts) to the CD boxes at all times the flywheel is turning. Therefore, with the key on, even with a completely dead battery, you can rope start your engine. When you turn off the key, White and blue wires are in continuity to ground and the CD boxes are grounded thereby stopping spark.
