Yyachtwork
- Dec 7, 2009
- 5
Hello- We are dealing with a 1993 4.3lx raw water-cooled MerCruiser. New risers, new impeller, new circ water pump, pulled oil cooler, and checked for restriction. We have also run Barnicle Buster through the engine twice letting it sit for about two hrs each time. The engine will slowly overheat at idle with muffs on. We use a laser temp gauge and both banks seem about equal in temp. We have a hot spot under the laser temp that I will post the photo and some vids of the water flow. We are running out of ideas on what the issue could be. I have read every overheat form on iboats that I can find and we still have not found the issue.
Dang, the system won't let me upload the video of the water flow.
The hotspot is about under the carb. When the engine gets hot we rev it up and it seems to move the hot water along and the temp gauge spikes for a few seconds then goes right back down.
I will post this and try to come back up with photos and see if I can make a link to the videos.
We are looking for some new ideas on how to find the issue.
Scott
Scott
