oxbeast1210
- May 14, 2010
- 309
1989 Evinrude tracker xp pro 150 hp model : te150slcem
thats the information of my outboard and thanks to the guys on this forum and a couple other sources i was able to get it running and it sounds great!
My problem now is that the alarm that sounds when overheating or low oil is constantly on even before i start the outboard read on if u care about the history behind this outboard ill make it short keep in mind this is what the last owner told me . takes the boat out shortly after alarm goes off lifts the cover and a red wire is meltd with a small fire and smoking . he gets towed in messes with it for about aweek and cant get is started. at this point he sells it to me and buys a new boat. The guys on here helped me get it running and everything works now except that the alarm is always on it is not a beeping sound its constant and starts as soon as i turn the key halfway
and continues after i start the outboard. before the incident the alarm would make a beep beep beep..... sound when the key was turned halfway and would tuen off after the motor was running just looking for some advice on where to start
thank you
thank you
