Overheat at low psi
Frankjones28
My alpha 1 gen 2 over heats at idle or below 50 psi. Once I increase rpms to get 50 psi. Engine runs at 140 just fine. Any ideas?
JoLin
I think you're talking about oil pressure, and in this case one has nothing to do with the other. I think you're saying that at low rpm's you have low oil pressure and an overheating issue. As you increase rpm's your oil pressure rises and the water temp goes down. Probably the water pump impeller. When was it changed last?
Frankjones28
Just boat the boat last summer. I just picked up an impeller kit. I will start there.
