Karl_Childers
- Mar 2, 2009
- 118
Greetings,
I have a 1988 Black max 200hp that is overheating. I have a good stream out of the tell tale, but the heads are really hot to the touch. I have no idea if the overheat sensors are working, but I am guessing not, and I don't really know where to start troubleshooting them. Anyway, I pulled the heads and exhaust cover, (and by the way I didn't snap a single bolt) and the heads were really really clean. So was the exhaust chamber other than a little leftover oil. The pistons and cylinders weren't all that carboned up at all. A little, but not much.
Someone before me has removed the t-stats, so all the above information is without thermostats. So what gives?? How hot should the heads get? I heard somewhere that Mercury has some sort of screwey grommet on the water tube at the base of the powerhead that gets messed up and restricts flow. Is this true on my 200hp? Any and all advise/comments will be appreciated.
thank you for reading my long post!!
Rob
Rob
