Re: Overheat Buzzer Test
Yes, as long as the ignition is on, it should be sounding-off when the wire is toiuched to motor ground.<br />If it does not, you have a defective buzzer,or wire going to it, or from the postive to the buzzer.<br />Any 12 Volt buzzer will werk. A buddy with a Contender had some heavy duty backround noise to overcome, so he hooked a car alarm up to the leads.
