Re: overheat/normal operation of water outlets
The hole/s out the back is a pressure relief port.
It allows excess water pressure/exhaust out the back.
The base of the powerhead,port side is a small plug held in by 2-5/16headed screws(DON"T REMOVE).
It the pressure relief spring and plug.It could be stuck.
The pump pushes way more water than the motor can use.The PRS works to relieve this pressure.
If your system isin't working right,no flo then it might be stuck.
As far as no water at speed.I'd start looking at the problem.
Mine works at all speeds.
The snout idea is wrong.The exhaust pressure will go out the snout no mater the pressure.
In fact the water going by the snout would even draw it unless the snout was on backwards.
