seattle2855
- May 21, 2009
- 29
I took my 1989 Bayliner 2855 (OMC 460 King Cobra) out today for a quick spin and 3 minutes at 1800 RPM in I knew something wasn't right. I was hearing these slight popping noises and started to smell burning rubber.
I opened the engine hatch and saw that the rubber exhaust sleeves from the riser and to the Y pipe were smoking a lot on the port side. I immediately turned around and headed back to the slip. I managed to make it in, but the popping and smoked continued.
After cooling down a bit I noticed the lower rubber sleeve to the Y pipe was melted on the port side. The starboard side looked fine and never smoked. I took off the riser and elbow to the Y pipe and noticed the exhaust flapper that should be there was gone (the metal pin it attaches to was still there). There was some remnants of the flapper but it was burned to a crisp. I took off the other riser to examine the flapper on the starboard side. That flapper had dislodged on one side but was still there. However, it did have signs of fresh melting.
The risers an manifolds ports looked open enough for water to come through and the hose from the heat exchanger isn't blocked (I blew threw it). I also replaced the impeller a little over a year ago. Also, the engine temp never got above normal. And if the impeller was the problem, why was the smoke and melting only on the port side.
Is it possible the flapper broke off on the port side and blocked the exhaust causing it to overheat? If it's stuck at the bottom of the Y pipe, how might I get it off (while still in the water). I'm trying to save a towing trip to a dry dock.
Any ideas would be appreciated. I have a new set of manifolds and risers I was about to put on, but I'd like to know the cause of the overheat.
Here's the manifold
and the flappers (port side missing)
Any ideas?
Shawn
1989 2855
OMC 460 King Cobra
Here's the manifold
Any ideas?
Shawn
1989 2855
OMC 460 King Cobra
