coolbri70
- Oct 6, 2011
- 1,554
I have an evinrude 9.9 with the 15 carb, I replaced the impeller and was going to test it at the river today, but there was too much junk in the water so I brought it home and ran it in the bucket the tell tale was squirting good so I left it run a little while. then I thought to take off the cowl for a look and noticed the paint burned off the top cylinder
, I felt it was very hot:faint2: so I shut it down. thinking it could be the thermostat, I removed it and tried again, the motor didn't get hot so I assume the thermostat is bad, hope I didn't destroy my motor:facepalm:, compression tester will tell, but its at work and they're closed till Monday. any other advice
