redneck joe
- Mar 18, 2009
- 12,147
Yes I've read the stickies and think I know what to look for but want to know 'normal' progression of what ones to start with.
35 year old boat, bought cheap as it was abandoned for slip rent. Sat inside for three years. Put new SEI on it first year. Maintenance unknown, form the look of the spark plugs when I replaced could have been 5-10 years since anything done.
Slow overheating under load this year, fine last year. Took to the shop to winterize and was talking to him. Asked him to pop off one side of the riser/manifolds to check condition as my first guess. He just called and told me no water coming from exhaust he thinks water pump but could be the usual suspects. He pulled the petcocks completely so not clogged there. I'm going to hold off until spring when we de-winterize and or this winter if I decide to do new transom. If I do transom will just do everything but if not I'll do the work in the spring.
So what order would you put these in to check: risers/manifolds, water pump, impeller (maybe 75 hours in two seasons), exhaust flappers, ?? (anything i've not listed.
