I have the Overheating alarm going off some times but the Temp guage shows everything is normal. I can see the Thermostat open and the temp go down on the gauge, It apears to open around 140 deg. It all works fine in the drive way with the water hooked up but out on the lake for a couple of hours and it will start going off. There is a good stream of water coming from the tale tale and if the alarm goes off you can speed up to over 3200 rpms and it stops. Please advise the next step.
