Mike Harding
- Aug 2, 2021
- 9
Hello everyone , my motor overheated from a bad thermostat and hydro locked , I replaced the thermostat and it ran normal with muffs on but when I put it in the lake , it hydro locked again, I pulled the plugs while on the lake and cranked it over and water was pumping out of the cylinders like a pump. Question is what can cause this much water into cylinders? Would a bad gasket do this? It’s a lot of water, no water in lower end of motor and again it didn’t do this with muffs on it , ran normally for 45 mins onshore and kept temp . Motor is 2005 Volvo Penta 5.7 Gxi-F
