Overheating engine shutdown
VisionIsle
Volvo AQ240A/270<br />This is an update to my previos email about my Carver shutting down from an overheating problem in the South Bay.<br />Back in port,<br />I Changed the impeller, old one looked used but still good.<br />I pulled the plugs, no water or fouling. Plugs look clean (changed them about 2 months ago). Oil in valve colver and hose coming from back of carburator all seem normal, no milky oil.<br /><br />What else can I check to make sure that the head gasket isnt blown or other internal damage from the overheat shutdown?
Don S
Re: Overheating engine shutdown
None of that other stuff is going to tell you if you have a blown head gasket or not, but a compression test and leakdown test will.<br /><br /> Service Bulletin 97-25
VisionIsle
Thanks Don<br /><br />Next chance I get I will take a compression check. <br /><br />Carden
