I have a 1997 Four Winns 21 foot Ski Boat that has a 5.7 Volvo Penta motor in it.
It is a 5.7 GXi ? The sticker on the outside of the out drive also says Volvo Penta SX.
It starts up perfectly fine and sounds great , in the beginning..!
When I put it in the water and ride slowly around (in no wake zones) it runs about 130 to 140 degrees and eventually gets up to 240 degrees after a few minutes of running.
When I enter the ?End no wake? zone, and throttle down about ? of the way, in about 2 minutes the temperature climbs up to about 240 degrees.
I then turn the engine off to let it cool down ? When I try to start it again (after 4 or 5 minutes of it being off) it is real difficult to start.
When I hook it up to the ?ears? and let it run idle in my driveway, I have no heat issue at all (ran it for 15 minutes)
I have Replaced the impeller that is on the motor ? Still didn?t fix the heat issue.
I have replaced the thermostat ? Still didn?t fix the heat issue
I even ran it without the thermostat ? Still didn?t fix the heat issue
I have been told by some people that this motor only has one impeller and other people have told me that it ALSO has an impeller on the lower unit too.
Besides the obvious question of do I have an impeller on just the motor or do I have one on the motor AND the lower unit , anyone have any ideas what could be causing the heat issue?
