hello all,
I purchased a '94 SeaSwirl with a TubroJet 115. I worked fine until .....
I winterized it last fall. Not having the special fitting, i disconnected one of the cooling line and used compressed air to blow the water out. then, with a hand pump, pumped antifreeze in after starting the engine. within a minute or so of doing this the high temp alarm triggered and I turned the engine off.
This spring I reconnected the house I removed and dropped it in the water. the engine started and ran fine. The coolant lines on top of the head had some water, but not much, flowing to the muffler. I would say about 50/50 air and water. (is that enough flow? and should there be air in it?) After 3-5 minutes the high temp alarm went off. I sprinkled a few drops (yes, just a few) on the head and they immediately boiled off so I know the heads where really hot.
Now, my question, what should I check? what should I do to fix the problem? I heard that I may have blown out an exhaust to water gasket with the air pressure winterizing?
thank you in advance
