bang4dabuck
- May 24, 2009
- 296
Just doesn't seem right that this is normal. I was told by an Evinrude technician ( Don, he seems pretty knowledgeable) that there is probably a problem with the WATER TUBE or the WATER TUBE GROMMET.
1) Do you concur that it should not overheat on muffs with sufficient water flow?
2) It seems if the tube is bad or just disconnected not too hard a fix. A hassle maybe but no biggie. The Grommet on the other hand opens a can of worms seeing as though I just sold my cherry picker.
a) Is there any trick to avoid pulling the head to replace a freaking $3 piece ???
b) Any way to insure that the Grommet is in need of replacing ??? BAD GROMMET ??? Water showing up in the LOWER ENGINE COVER say . Any sure signs ???
thanks
thanks
