mr300z87
- Sep 15, 2010
- 698
I Have been trouble shooting an over heating problem and I have a question regarding water/exhaust flow on a Mercruiser Alpha 1 Gen 2. While running the engine on the hose I notice there are what look like exhaust ports on the bottom of both sides of the gimble housing one side has water coming out and the other does not. My question is should water and exhaust be coming out of both sides and through the prop? If so could this be caused by a clogged exhaust? Which in turn is causing a high speed overheat problem?
Going to pull the riser tube and end caps later today will post my findings. Hopefully with no broken bolts.
