I bought this 1997 nitro with overheated motor (didn't know at the time) I replaced the heads w/ brand new ones.Replaced the impeller.w/complete new unit.Replaced all the head bolts. After the impeller replaced had 30 psi or more at 2500 rpm.Replaced the poppet valve.And inspected the impeller again.The alarm sounds 5mins after on plane. Stops when I slow down to idle after 3 mins.I also replaced both thermostats when I did the heads.I think I have some thing plugged I just don't know where to go digging.The boat runs great 125 in all cylinders,???? any help would be appreciated (Note before the impeller was replaced I had normal pressure readings on my pump gauge.I have put 2 new impellers in since no change).
