Overheating z250 turb hpdi
Payjobs
Over overheating at idle. Has new t stats. Port head at 170 the starboard head at 130. Pee stream is strong. Both t stat covers at 130
have you changed the water pump?
if you boat in salt water, have you cleaned out the cooling system to reduce the salt deposits?
Payjobs
Water pump 2 years old. Would a bad poppit valve cause 1 head to be hotter than the other.
