Chrisglastron
- May 27, 2013
- 9
I have a 2001 volvo penta 5.0 gl and have had intermittent overheating problems over the past ten years due to milfoil weeds in the lake I keep my boat. They get clogged up in the lower unit and I need a coat hanger to remove the clumps. So this year I was getting the boat started and noticed not a lot of water of water coming out of the lower unit hooked up to the muffs running. I touched the exhaust manifolds and they are hotter than normal. So I shut the motor off and disconnected the feed line to the impeller and turned on the hose noting good flow to the impeller and restarted the motor with no problems. I then started the motor the next day and same problem. I changed the impeller at the end of last season as well. So I changed the thermostat today and everything worked perfectly so I brought it to the lake. Sure enough same problem at the lake but I left it in the water hoping it would be easier to diagnose in the water. I did not have many tools with me but a flathead. So I took the feed hose to the thermostat housing from the impeller off and started the boat. No water coming out of the hose but there was water coming out of the thermostat housing. Where do I go from here?
