i have a 1987 mercury 60hp 3cyl auto lube that the heat alarm goes off in
warm summer water(over 75degrees).i can run the heck out of it in 60-70
degree water in spring at 5200to 5600 rpm and no alarm??? this has been
on going for 4 yrs.the water pump has been changed out 3 times by 3 different repair shops here in richmond,va and still no good? water comes out of pee-hole fine. last shop ran it in dyno tank and it never got over 143degrees??...the ser# is b259512 on the motor.
2 yrs ago found out it has no thermostat/poppet parts in water jacket???
dont know if that might make it run ok at high speed? i did find 2 broken
off water pump impellers in water jack this last month. which i thought
would cause this trouble, but no such luck.
if anyone out there could let me know if i should buy all the parts for the
thermostat/poppet assembly and install it........PLEASE LET ME KNOW!!!
I AM GETTING VERY UPSET ABOUT THIS TROUBLE and none of the so called
"EXPERTS" can get this fixed???
ricknel
804-276-2806
ricknel
804-276-2806
