ow to determine where the noise is coming from
captain zac
6.2 BIII MPI 2001 Chap 265
Getting a noise like a bearing squiking
pretty sure its the power stearing pump or circulation pump
its just hard to tell where its coming from
Question
can I spray some WD 40 (or something else ) on the shaft of these and determine which one it is
thinking maybe the noise will go away for a moment
PS
I am getting no water leaking from the circulation pump or power steering fluid from the power steering pump
Re: ow to determine where the noise is coming from
Ayuh,.... Pull the belt off, 'n turn 'em by hand, you should be able to "Feel" the bad 1...
captain zac
Will try
Just hoping that I could determine what part and have it on hand when I removed the belt
I like to do everything at once when I can
Thanks
Harry
