OX 66 Trim & Tilt
No more boats
2000 OX66
250 HP
Part # 6 1 A-43800-25-4D
Seals were leaking ,
changed
Release valve would not open
Should have left alone since it was working , BUTTTTT no anal me had too make everything perfect
Now unit not holding pressure , stripped head of release screw , tried drilling out and really messed it up
Soaked bolts and heated too remove , no luck , soon as pressure put on bolt head they snapped uneven , Only one bolt came out
Now I have no options , must remove trim & tilt and try too fix screw assembly or replace with good used ,
Drill out 3 bolts trying not too damage threads or if I can separate enough too put a saw zall and cut
Bottom on trim & tilt is that a long bolt held in place with C Clamp
thanks in advance
