As mentioned in an earlier post about 0x66 lower unit I have one that is knocking after a pump kit install. I found the slip collar was crack and replaced it as well. I hammered the outer collar down over the inner collar until it would go now further without damage. I did notice wear on the drive shaft a few inches above the pump. It was inconsistant wear on what looks like a seal journal. The wear was actually just a polished area on the shaft, not material worn away. Can some one explain the knocking cuased by the slip collar? Or do I have another problem? It an 150 ox66 2003
Thanks
Thanks
