onebohemian
- May 19, 2003
- 43
'87 Evinrude V4 90hp E90tlcur.<br /><br />Thought I'd pick up a set of new washers/o-rings for the drain and top plug of the lower unit. My top plug only has a nylon washer on it and the bottom plug with magnet only has a rubber o-ring. The parts schematic appears to only show one or the other on each plug but the part number chart lists both the nylon washer and the o-ring part number for each plug. Is each plug supposed to have both the white nylon washer and black rubber o-ring? (This may sound trivial but it's bugging me.)<br /><br />By the way, part numbers I see are 311598 for nylon and 333572 for o-ring.<br /><br />Thanks, <br /><br />Mark<br />Mpls, MN
