Re: Paint blistering/corrosion-aluminum boat
I just went thru this a couple of years ago, with my 74 Starcraft 221 Islander.......<br />Before I painted my hull, I noticed that anywhere there
Wasn't any paint left, I had tons of Pin-Holes...... The Original paint was getting pretty thin over most of the hull....<br />Anyway, I sanded, zinc primed, sandable primed, sanded,+ sanded,+ Shot it with a 2-part Urethane paint..... <br />I then added 3 coats of brushed/rolled Rustoleum, Below the water line........ Being a trailer boat, I now just touch up the bottom a couple times a year, with just a disposable brush....<br />After all this work I found some more pits in some scratches......<br />I found that by Bonding the boat, the Hull should be bonded to the engine, just like the outdrives are bonded to the engine...... This gets everything on a level playing field, so to speak.....<br />Then, You have to Ground All of your Electrical Circuits Directly to the Batteries.......<br />And the Pitting Stopped.....<br /><br />AAnnndddd, The Added Bonus of a Properly Bonded Aluminum Hull(Cabin prefered)........<br />Is the Safety Factor of the Faraday Cage Effect,<br />In case of Lightning Strikes...........
