jeremy5780
- May 8, 2008
- 147
I have this fiberglass boat, and I want to give it a fresh paint job. However I cant get the old paint off. I have tried marine paint stripper didnt work I tried 60 grit sanding it did smooth the surface but didnt remove the paint I even tried sand blasting NOTHING. I would just paint right over the paint on there already except the paint has tiny hairline cracks all over it like and eggshell when you crack it. I was wondering if I could just sand it smooth then use a high build primer to fill in the inperfections then paint over it? What do you think. and what should I use if I do this. thank you
