paint problem
pursuit2460
ive looked though the posts and couldnt find the answer i was looking for. i recentley painted my boat with valspar topside marine poly. paint but something happened with the paint gun and before i knew it i could doanything about it.the paint looks like it was painted with a spary can it got little dots and haze in some places. can i wet sand or use rubbing compound and the wax it to get the shine back on this type of paint thanks
aspeck
Re: paint problem
Without seeing it, it is hard to say. Try it on a section and see if rubbing compound on the lighter places and wet sanding on the heavier places help.
crazy charlie
Re: paint problem
Sounds like you have a condition that is called "fogging" which can happen when painting in too much humidity or if it gets too cold out while spraying or drying.Charlie
