I previously posted about my tale of woe trying to paint my boat with one-part polyurethane. (Blue Water Marine Mega-Gloss Polyurethane).
I had first tried the roller, then the brush. In the roller case, I had roller marks and lap marks. In the brush case, I had brush marks, and lap marks. (The roller coat was thinned about 10% with Hi-Flash Naptha, as recommended, and I had curtains and some sags). The brush application was UNTHINNED, and there were Trophy Sags and curtains with that application. It's shiny alright, but it looks like woodgrain instead of fiberglass.
I've begun sanding it smooth, again, with 220 grit. Now, my thought is to either try spraying it (maybe using mineral spirits and a paint viscosity cup) and hopefully with an HVLP gun.
My question is whether HVLP is the way to go, or just shoot it with acrylic enamel with hardener, like I used to paint cars with, in a conventional gun. The overspray is my concern, as I will have to build a plastic-covered structure temporarily to house the spraying. The boat is a 20' center console.
Any ideas? Should I try to spray the polyurethane, or just get some other paint and some good primer?
thanks
thanks
