paint removal
bhm25
looking for some tips on the fastes way to remove paint. theres only 2 coats of an epoxy based paint that needs to be removed due to peeling (never prep'd riight 1/2 A** in a barn in maine) ..... is a grinder with a 36 grit 4 inch disk a good idea ?
drewpster
Re: paint removal
I use fiberglass safe strippers on fiberglass, sand wood. Use a grit that does as little damage to substrate as possible while removing paint. It will save a little work later.
Tail_Gunner
Re: paint removal
Absolutey not even, that is if it was mine, Take a little time to safely remove the exisiting paint, the actual painting is child's play compared to what you are doing now. What i am saying is the work you are doing now should be as careful and detailed as you can be, it will be the foundation of your final paint job and effect it's beauty greatly.
I cant imagine how tough a paint could be to stand up to a 80 grit sand paper?
ondarvr
Re: paint removal
If it's starting to come off on it's own, then a pressure washer may take off most of it.
Bob_VT
Re: paint removal
On fiberglass or wood boat? A heat gun and some scraping might help. 36 grit will leave you with ton's of finish work.
bhm25
Re: paint removal
well before you guys have visions of me grinding up a nice silky smooth boat this is not the case. lol its a rough glass finish with mat BY FAR from the finish of a molded piece. 80 grit gets chewed up every 6 inches . thanks for the tips ill continue on with the 80.
Tail_Gunner
Re: paint removal
I see says the blind man.............. but then there are no pic's , hmmmm can you say "PICS" Ok rant over, with pic's there are people here that can and will guide you to a successful end.
