Paint vs Galvanized
NHGuy
Can I repaint or repair small rusted areas of a galvanized trailer? Ideally I'd repaint the entire thing to freshen it up. But if galvy is best left alone I can easily use it as is.
robert graham
Re: Paint vs Galvanized
You can buy a Zinc "galvanizing" spray paint to touch up any rusted areas.
tpenfield
You can.
You might want to use something like ZRC (zinc rich coating) as the paint.
robert graham
With any rusted areas, I'd scrape, wire brush, sand and prime area as much as possible before new coating...any rust left on surface can re-appear pretty darn quickly...especially if you're in salt water...
tanuki
Paint/Primer will not stay attached to galvanized for very long.
Use "Cold Galvanizing Compound"
Lowe's and Depot have it on the shelf in the Rustoleum section.
How long is"not very long"? Just curious as I used Rustolium latex primer for "aluminum or galvanizrd metal" on my old galvanized trailer before I painted it.
UncleWillie
...I used Rustoleum latex primer for "Aluminum or Galvanized metal" on my old galvanized trailer before I painted it.
Use the correct primer and it very well may hold up for a long time. :D
Use regular Rustoleum and it will come off the next day with just a piece of masking tape. :eek:
Don't ask how I know! :facepalm:
minuteman62-64
The cold galvanizing stuff works very well. Here in San Diego, if the dealers make any modifications to the galvanized trailers, they use it to repair the area where the galvanizing was compromised. We had a boat trailer at work where this was done - by the time I retired, it had been used (lightly, I should point out) for four years, strictly in salt water, and there was no rust evident in the repaired areas (there actually were a few rust spots on other parts of the trailer where road debris had chipped away at the galvanizing).
I think surface preparation is as important with the cold galvanizing compound as with regular paint. About 20 years ago I made a bracket to support a fence post at a site where I do volunteer work. Bracket was forged from mild 1/4 inch mild steel bar. Then I preped it with some of the stuff you'd use for re-painting an auto body (wire brush, cleaner, etcher, as I recall). Then the cold galvanizing. I was by there a few months ago and the bracket is still there, sitting in the open, no trace of rust.
