Painting a trailer
nightvision
Hi all,<br />I'm in the process of storing a boat trailer that will be used in fresh water only. Here is the process that will take.<br /><br />1. remove rust with wire wheel/sand paper<br />2. apply Naval Jelly (rust neutralizer) <br />3. wash, clean, and dry<br />4. apply primer<br />5. apply bondo in some area<br />6. apply final paint<br /><br />Did I missed any steps? What type of paint will hold up. I'm considering using Rustolium spray for the primer and paint. Thanks for you input.
Re: Painting a trailer
That Should Work..........<br />But, Switch 4 + 5........<br />1,<br />2,<br />3,<br />5,<br />4,<br />6........
gewf631
I used bed liner for my paint (the stuff for pickup trucks). It's not nearly as pretty, but I didn't have to do steps 4 & 5, and it sure is durable! Also, it makes a nice non-skid coating.<br /><br />Just my .02
Chris1956
Night Vision, I am not sure what the bondo is used for, since it has little strength. If you have holes in the frame, you might need to visit a welder and have him attach plates to restore strength.<br /><br />I recommend rust inhibiting primer. I have used Rustoleum Rusty Metal Primer and a brush to apply it with good results on a painted steel trailer used in salt water. The primer, however is not compatable with all top paints(due to its fish oil base??). I would ask a paint guy for a compatable top coat or experiment in an inconspicious area. I left mine uncoated, without issue.
