Painting fiberglass
NewbieBoater
Hi folks. I've re-painted the bottom hull with anti-fouling paint.<br /><br />At the top part of the hull, there is a blue type paint on the fiberglass and I'm wondering if I can repaint it? If so, have any recommendations on what kind of paint to buy?<br /><br />Also, what can I do to clean up fiberglass/gel-coat?<br /><br />Thank you!
crazy charlie
Re: Painting fiberglass
What condition is the paint in????? There are great products at West marine to repaint the hull .There is something called Toplac paint that is a great all around paint.it can be brushed or sprayed.Charlie
NewbieBoater
The paint is like dry/dull/and flaking (if that makes sense). The boat is an 85 so it's to be expected. just trying to make it look better and perform better as well :) Is that paint shiney? <br /><br />thanks.
crazy charlie
Yes the Toplac is designed to give you a sprayed look when brushed and it has a great shine.You will have to get that old paint off before you put any new paint on.I would start with a pressure wash to see how much of the flaking paint comes off.Then sand the rest.The prep is the most important part of the process.Charlie
NewbieBoater
crazy charlie,<br /> I've pressure washed already --- thanks for the advice. I'm assuming that I'll need to sand that area. Any recommended sand paper type cause I know they come in different grits, etc, etc, etc.<br /><br />Thank you, you've been a huge help!!!!
crazy charlie
Best to stop in an auto body repair shop and pick up a few.start with a medium and work down to a fine.The paint can will tell you exactly what to use.I was a kid when i did it and i did all the steps but pretty half assed and it still came out great.Charlie
lenny2113
NewbieBoater,<br /><br />Below is a picture of the boat I painted with Introlux single part paint. We used a pro spray gun and results are great. The key to how your finish will look is based upon the preparation work you're willing to put in. I have to tell you this: If I were to do it again I would try to restore original gelcoat by all means. <br />I would not want to go with painting again. <br />Befoore I started I was very excited about it. But then it all begun:<br />You will have to sand sand and sand... Invest in orbital sander from the start. <br />I started with 150 grit for primer prep.<br />250 grit between coats of primer<br />320 grit between coats of paint<br />500 wet after final coat<br />1000 wet final<br />Polish compound.<br /><br />I used primer before spraying paint on the boat. <br />After coat of primer sanding fun begins. <br />Then next coat of primer. <br />Sand again.<br />Paint first coat of paint, sand.<br />Second coat, sand :) <br />Third coat wet sand.<br />Polish with heavy compound.<br />Light compound.<br />Wax...<br />Done.<br />I hope it helps a little. <br /><br />Easy right :)
lenny2113
NewbieBoater,<br />I also forgot to mention one thing.<br />I thought that painting project will take 2 weekends to finish. :) Soon after I started I realized the labor involved. It took April and May (2 full month) of weekends and evenings to get it done. But the results are rewarding.<br /><br />Good luck with your project.<br />Lenny
