Painting Hull: What paint, and What to use to fix little nicks, scrapes, and chi
ShawnQ
I am thinking about painting the sides only on my 189T Blue Wave bay boat. The sides have a clearly taped off area that is blue, and the hull bottom is light grey. <br /><br />There are a few nicks/scrapes/scratches in it from rubbing against docks, oil rigs, etc..<br />A few of them are deep enough to where they are through the paint, and the glass is showing (however, they dont leak). <br /><br />What would be the best thing to fill these with before I go ahead and paint the sides?<br /><br />Also, the sides of the boat are low impact, and dont need a really thick paint on them. I was thinking about taping off the area I wanted to paint and spraying some DuPont Base/Clear on it, or maybe Centari or Imron. What would be recommended?<br /><br />Thanks for any help/tips.<br /><br />Shawn
Solittle
Re: Painting Hull: What paint, and What to use to fix little nicks, scrapes, and
For the nick & stuff Marine Tex is the absolute best. It is a two part product and is as hard as steel when cured.
ShawnQ
Thanks for the response.<br /><br />That's what I've heard. I'll have to look into it.<br /><br />Shawn
Fly Rod
Marine tex is great stuff when used where it won't be seen but if you were to gel coat over it the gel won't hold good.<br />Best bet is to gel coat and then sand out especially if you think of resale. May be a little more work but worth it.
ShawnQ
FlyRod,<br /><br />I know that an automotive paint will shine as good or better then gel coat. <br /><br />Gel Coat is a bit too much work...<br /><br />Will the automotive paint hold up?
phatmanmike
not unless its specially formulated for shose new swimming cars they got.. think about that one
ShawnQ
phatman,<br /><br />you being in florida and all...you can probably attest to this. <br /><br />First, Does your car have a basecoat/clearcoat paint job? Does it still shine after 8hrs of constant rain wen one of those little tropical storms blows thru? If not, you need to take it back to the dealer.<br /><br />Put a car with base/clear in the weather/sun for 6yrs, untouched, vs. a gelcoat in the weather/sun for 6yrs, untouched, and I assure you the base/clear on that car will look a lot better then the gelcoat on the boat. The base/clear has better UV protection then the gelcoat, and it is a lot easier to 'bring back' the shine if it does go dull.<br /><br />My main concern is how it will do with usual boat wear/tear like boat docks, sand when beaching it, etc..<br /><br />There are a few guys I've found since I posted this who used base/clear on their boat, and it turned out like new, and has lasted them. One guy has had it on their for 6yrs and only has a few small areas of imperfection (on the bottom side) due to fishing in stumps and trees.<br /><br />Do you have any info to back up your claim that it wont hold up? I'm curious, just saying 'no' isn't enough.<br /><br />Thanks!<br />Shawn
ShawnQ
I forgot to mention that the boat is stored out of the water, not in the water. I would never consider leaving the boat in the water with this paint. <br /><br />But, it will hold up to the water after 8hrs of use in a day, and then being pulled out, air dried, and the cleaned.<br /><br />Just thought I'd clear that up!<br /><br />Shawn
LubeDude
Personaly I have "never" seen a properly applied urethane basecoat clearcoat fail either obove waterline or below waterline! And I have seen lots of Gelcoat failures, even new! The key is properly applied! PREPORATION IS THE KEY! I know it is not recomended, but I think the paint manufacturers say that to cover there bu**s!
ShawnQ
LubeDude, <br /><br />The people I have talked to that have it done are 100% happy with it. They say it's easier to maintain, it's glossier then new, and it is cheaper/easier to do.<br /><br />I found a guy near me in Austin, TX that does nothing but Paint boats and restore them, as well as re-floor and install stringers, transoms, etc...<br /><br />If you think about it, all of those $300,000 Cigar Boats and what not with the designs on the side...those are custom painted, usually with automotive paint. That's what the guy in Austin does a lot of. He said the main problem he has is when people spill gass on it, which is typical.<br /><br />I'm going to give it a shot eventually, just the hull sides first to see how it is. I'll post up when I do.<br /><br />Take care<br />Shawn
GetReel
I used urathane on a 1974 23' mako cc about 10 months ago done the top of the gunwhales-bow and inside the freeboard down to deck, she got fished out of hard all summer & fall rod&reels 32ounce mojos big planer boards bangin around, standing on the bow catchin bait with heavy a** trow net and after a good wash down the urathane looks like the day i painted it, prep the surface right use the correct amount of hardner and your golden------------<*)(((><{
