Anthony555079
- Jul 24, 2016
- 4
I desperately need some sound knowledge on re-spraying a fibreglass boat.
I have been told to sand the hull with 120 grit wet/dry then prime with 2k epoxy hi fill primer followed by sanding the primer with 320 grit by hand or 240 grit on machine before applying the final coat.
But then others tell me to use a wet/dry 600 to 800 grit before the final coat.
I have access to a spray booth but little knowledge with spraying boats.
First post, sorry if i'm not making sense.
