Painting over new poly laminate - leave tacky or let cure?
skunkedskippy
Just finished glassing in new stringers, and will probably add an extra layer of 1708 inside the entire bilge. I plan to paint the bilge, probably with Rustoleum enamel. That said, should I leave the last laminate tacky, or should I let it cure? And what type of prep should I do with either method? For example, If I leave it tacky, I assume sanding would be futile. Using poly laminating resin, if it matters.
I plan on testing both methods with some scraps, but I'd love to hear from the experts.
matt167
I think you'll have to wax the last layer so it does cure. Rustoleum won't work well on a soft sticky substrate
Woodonglass
Do NOT paint over tacky resin. Tape some plastic over the bilge after the last coat of resin. It'll cure to a non tacky surface within 24-36 hours. Then light sanding with 180 grit wipe down with acetone and then paint
or paint it with gel coat over the tacky resin
AShipShow
I plan to do what Scott said... a layer of waxed gelcoat than bilge paint over the gelcoat in the bilge to prevent staining from oil and grease
skunkedskippy
Ok, glad I asked. Guess I won't waste my time testing this. If I had extra gel coat laying around I'd take Scott's advice. Could I just add a layer of waxed poly instead?
skunkedskippy
Thanks again all. Added a coat of waxed poly yesterday.
How would I prep it now, for painting? Seems like I would want to remove the wax. But would it go back to being tacky if I did so?
Edit: reread WOG's comment. Sounds like once laminating resin is surface cured, it won't go back to being tacky. I'll give it go!!
