trooper1822
- Mar 2, 2013
- 65
So my boat restoration is coming along nicely. I completely gutted the inside as most of the floor was rotted out. Boat is a 1981 sea ray 190. Got the floor all put back together and finally got started working on the hull. After prepping the hull for the past few days I got to the point of starting the paint job. As I am doing this on a strict budget I decided to go with rustoleum paint. I watched many videos of the roll and tip method of painting but decided I would try a different route. I picked up a Wagner HVLP painter for 40 bucks. I have used them before for painting fences but never for a boat. After unpacking and reading up on the directions I loaded it up with rustoleum white primer. I thinned it down using the supplied cup to 40 seconds and also added japan drier. Once mixed I shot a few test sprays on a old piece of glass and got the flow down. Spraying the primer was a breeze. I did manage to get a few run spots but that was completely my fault. I sprayed 2 coats of primer with sanding in between. I am going to let it cure for a few days and then hit it back up this weekend. On to the fun part, the paint
Only thing I do not like about the painter is it has a tenancy to shoot globs on the initial pull of the trigger if it has sat for a few min. The trigger is a two part trigger. When you first pull the trigger it starts the fans and will only blow air. Depress the trigger more and it starts the spray. So I learned that after it has been sitting to spray away from your painting surface for about 2-3 sec to clear any globs out then continue with your painting. So if you do not want to try the roll and tip method or do not like the results, this is a easy way to go.
