fishchris361
- Sep 3, 2005
- 21
thank you for the reply, god bless, no one seems to want to talk about this subject. what exactly do i need to do? tell me if this is right
1) i find physical tdc on motor,(2) i run motor,(3) i go into timing verification,(4) then look at ecu timing on computer,(5) then i use timing light on motor,(6) then i add in my 3 dagree incraments to match the timing light timing to the computers ecu timing reading. is this right? i have done all of that and the actual physical timing light timing stays the same on both motors. (stb motor stays at 6 dagrees btdc) and (port motor stays at 22 dagrees btdc). maybe i should try running the program in windows 98 startup and not in startup dos promt?
