parallel batteries
jwhitm
is there anything wrong with using batteries in parallel ? what would be a
good charger to use ? should i use a 1 or 2 bank ?
thanks
jtexas
Re: parallel batteries
nothing wrong. charge 'em together with a 1 bank charger - it'd go faster if you used a 2-bank, but you'd have to unhook 'em from each other.
bruceb58
I would suggest getting a switch where you could parallel them when you absolutely have to. By paralleling them you pretty much give up the redundancy of a two battery system that would help you get started in case you left something on and completely drained the parallel battery setup.
PondTunes
What are you going to use them for? 2 in parallel for extended run time? Like bruce suggested if you go with a switched system you can seperate your loads from your cranking battery, thus ensuring you always have plenty of power to crank the boat.
If you are looking for a simple automatic battery charging/switching setup check out this thread:
http://forums.iboats.com/showthread.php?t=215068&highlight=add-a-battery
jwhitm
if i go with a switch ; what would you suggest ? as for use, 2nd battery is
for electronics,radio ,ect. i've been using 1 batt. for every thing but would
like the extra protection.(starting 150 yamaha 2 stroke )
thanks for info
PondTunes
My vote is use one for starting, the other for your electronics and such, Although it being an outboard you might want to ask around to see how your outboard will do charging 2 batteries!
bruceb58
It will charge them fine given enough time. The problem, of course, is it may be a really...long...time.
C-VENN
i have been thinking about this for a while.
What i am going to do is
1 cranking batt
1 group 27 trolling batt
1 perko 2 batt switch
1 2 bank charger 5 or amps per bank
Link the motor and all small electrical to the cranking batt, and the radio and all large draes to the troll batt
I will wire the + of batt 1 to the switch and the + of batt 2 to the switch, along with only the + from the motor to the common post on the switch.
If i am correct Then you leave the switch on #1 to start and charge out crank batt, while letting all the high amp draws suck the troll batt dead, leaving your crank batt fine. You can also switch to #2 while under way to charge batt#2 but like has been mention my takes a long time. or both the charge both at the same time or start from the 2 batts.
the only thing i am not sure of is you may have to link the neg terminals together or split the negative to the 2 batts coming off of the motor.
The use of the 2 bank charger is the assure never a dead batt, worth the extra $100 rather than a problem on the water.
jtexas
a caution if you plan on switching while the engine's running........if your switch breaks the connection of #1 before making the connection to #2, even just for an instant, you risk smoking your rectifier, in which case neither battery will charge.
C-VENN
That is why i listed the "perko" switch. it is a marine grade switch, $35 may seem like alot but do not save money by using a cheap switch. It makes the connection before it breaks. The only problem with the switch is it is very big like maybe 3-4" diameter
PondTunes
Yeah use a make before break switch like the perko, if you're not going with an automatic setup. But either way you do it you can link the negative terminals of the batteries together you do not have to run each one to the engine.
jwhitm
thanks for input from all. i went with the perko switch. super simple to install and use. once again thanks for input.
