Part ID help / replacement 1992 75 hp merc
Trying to find a list of parts for what goes here, Ive looked at several charts but doesnt help I dont know what its called to pin point what I need.
See pics for reference.. any help would be great!!! worse comes to worse I can remove this bracket and get a machinest to weld / refil it no prob.. odds are cheaper then replacing it whole.. but would still help to know what exactly all goes there to make sure im not missing anything!
right now there is quite a bit of play in there and the snap ring doesnt hold in place one bit.
Thanks!
I dont think I need one or so I hope I dont!
What would all be intailed to change / add new bushings and fix it so that the snap ring holds? I came across one thread but the guy said you have to take the power head off?!?!
Yea its 0D176094... I am pretty sure judging by the pics I took the swivel shaft is done and needs replacing... I dont want to tear into it to do it yet mid season.. hopefully be able to make it last until winter.
Even the manual I have doesnt say what is needed to do this job I am only going off of what ive read on here for the most part which is you need to lift the power block to access it
