Part interchange
kbh121956
Hello group,
I own a 1963 Mercury 650 4 cylinder. I was wondering what parts will interchange from newer 60's early 70's 65HP 4 cylinders?
merc850
I think that the only upgrade would be Thunderbolt ignition which would require the Lightning Energizer, switchbox and coil; (ignore the color coding) if you're lucky the splines on the Ignition driver will match.Merc-500-wiring.jpg
you could also replace the plate rectifier with the diode type.
jimmbo
Not many parts will change as Mercury made major changes in 1964, in their effort to Silence the Beasts. Though things like Carbs and Ignition are likely to be transferable.
