Part numbers for raw water pump rebuild.
Lakemac2
I have a VP 5.7 gxif and the raw water pump is leaking,I've seen various videos on YouTube as to how to rebuild it, should be easy if I can source new parts.Would someone out there have part numbers and/or sizes for the bearing and the seal? Yes I am aware that rebuild kits are available but not in Australia where I am. Plenty of kits come from the USA with delivery in mid to late February, can't wait that long ( summer is disappearing fast, with very little boating happening). The impeller and o-ring were replaced in December so the bearing and seal is all I need.
Any help would be greatly appreciated. Cheers.
alldodge
The only guy I know that is where your at is achris and he is a Merc guy but may know where to get the parts
Fun Times
To help double check with finding the correct part Volvo numbers, it may be helpful to know/have your engine serial number and/or product number. http://www.volvopentastore.com/mall/template/store/volvopenta/help.html
If it's truly a GXI-F then the following link should help get you the info needed. http://www.volvopentastore.com/Mari...on_id.446125560--store_id.366--view_id.765158
Find the part numbers you need in the cooling system and either search the numbers online, EBay or call some dealers in your area.
Dave-R
I rebuilt the sea water pump on my 2011 5.7GSI a few months ago. I found all the information on you-tube. Getting the pump apart for me was the tough part. I had to make a little oval washer with my grinder to tap the bearing out. Total cost for the new bearing and seal was about 35$. I did have the part# that was on the bearing and it was a double seal electric motor grade bearing. The seal I got on E-bay . Works like a charm. My father was a machinist, and I can't help trying to repair things, instead of buying a new one. Let us know how you did. Dave-R
dypcdiver
Take it off, take it apart and get the bearing and seal from your local motor factors.
Bearing on mine was from SKF No. 6006-2RS1 and a spare seal made from Viton (better wear resistance) dimensions are 16x28x7mm. TB / R23 metal cased double lip viton rubber metric rotary seal with SS garter spring. Best of luck, it is an easy job.
billbayliner
Complete stock list of Volvo Engine Cooling Pumps :
804959 is Jabsco model # 9400-0001 pump
807368 is Johnson model # 10-35157-3 pump
820694 is Jabsco model # 10770 Series pump
822787 is Jabsco model # 10770 Series pump
825916 is Jabsco model # 9900-0001 pump
826456 is Jabsco model # 22740 Series pump
828026 is Johnson model # 10-32621-2 pump
829895 is Johnson model # 10-35098-3 pump
831178 is Johnson model # 10-32058-1 pump
833415 is Johnson model # 10-35157-3 pump
833522 is Johnson model # 10-35157-3 pump
833883 is Johnson model # 10-35157-3 pump
836326 is Johnson model # 10-22335-3 pump
837370 is Johnson model # 10-24017-3 pump
837371 is Johnson model # 10-24017-4 pump
837915 is Johnson model # 10-24017-4 pump
837916 is Johnson model # 10-24017-3 pump
837917 is Johnson model # 10-21915-2 pump
837920 is Johnson model # 10-21915-2 pump
837922 is Johnson model # 10-24017-4 pump
837923 is Johnson model # 10-24017-4 pump
838314 is Johnson model # 10-24061-4 pump
838522 is Johnson model # 10-24130-2 pump
840557 is Johnson model # 10-24178-2 pump
841860 is Johnson model # 10-24228-1 pump
842274 is Johnson model # 10-22335-4 pump
842275 is Johnson model # 10-22335-4 pump
842843 is Johnson model # 10-24061-3 pump
844971 is Johnson model # 10-24130-3 pump
846354 is Jabsco model # 10770 Series pump
846355 is Jabsco model # 10770 Series pump
846356 is Jabsco model # 10770 Series pump
855517 is Johnson model # 10-32621-2 pump
855578 is Johnson model # 10-32621-3 pump
856952 is Johnson model # 10-24228-1 pump
857451 is Johnson model # 10-24228-1 pump
858065 is Johnson model # 10-35157-1 pump
858150 is Johnson model # 10-24268-4 pump
858408 is Johnson model # 10-24268-5 pump
858469 is Johnson model # 10-24277-3 pump
858470 is Johnson model # 10-24277-4 pump
866739 is Jabsco model # 10770 Series pump
3829310 is Jabsco model # 10770 Series pump
3829311 is Jabsco model # 10770 Series pump
3852398 is Sherwood model # G9901 pump
3852399 is Sherwood model # G9902 pump
3855079 is Sherwood model # G9903 pump
801277 is Jabsco model # 920-0001 impeller
803729 is Jabsco model # 4528-0001 impeller
804696 is Johnson model # 1026B impeller
807904 is Jabsco model # 836-0001 impeller
818680 is Jabsco model # 4598-0001 impeller
825940 is Jabsco model # 1210-0001 impeller
825941 is Jabsco model # 920-0001 impeller
825942 is Jabsco model # 836-0001 impeller
831182 is Jabsco model # 4568-0001 impeller
833550 is Jabsco model # 42528-0001 impeller
833995 is Jabsco model # 22405-0001 impeller
834794 is Jabsco model # 22120-0001 impeller
835182 is Jabsco model # 4568-0001 impeller
835512 is Sherwood model # 9959K impeller
835874 is Sherwood model # 10615K impeller
842857 is Johnson model # 802B impeller
844683 is Johnson model # 802B impeller
845796 is Johnson model # 802B impeller
860203 is Jabsco model # 1210-0001 impeller
875573 is Jabsco model # 4568-0001 impeller
875575 is Jabsco model # 4568-0001 impeller
875583 is Johnson model # 808B impeller
875593 is Jabsco model # 920-0001 impeller
875660 is Jabsco model # 836-0001 impeller
875697 is Jabsco model # 17936-0001 impeller
875807 is Jabsco model # 4528-0001 impeller
875808 is Johnson model # 1026B impeller
875811 is Jabsco model # 1210-0001 impeller
897055 is Johnson model # 1026B impeller
3854286 is Sherwood model # 9959K impeller
