Partial floor replacement
taj
1986 Searay Seville. Just happened to put my heel through the floor on Sunday. It was near the center driver's side on a corner (had a screw through it), so I think I'm lucky that I can replace a piece instead of the whole floor. When I lifted the carpet, the wood underneath was dry and brittle. Is it possible to replace just a part of the floor? What material is best?
Thanks.
Bob_VT
Re: Partial floor replacement
Tip of the iceberg!! Find out what is below it and find out why that spot rotted. Patching a piece of floor is like putting a bandaid on your finger for a heart condition.
You must investigate below deck.
Kevin70
And don't just look. Tap around with the butt end of a screwdriver so you can "hear" the rotten spots.
Chris1956
Taj, My '88 Seville's floor rotted out in two distinct sections. The balance was unaffected, and under the floor was a layer of fiberglass which protected the foam. Unusual to say the least. I would look at the floor for spots where the chop gun either missed, or ran out of "chop". These will rot first. You may get lucky and only that small section needs to be replaced. Also, on my SeaRay, they put hardwood 2X4s under the floor with bolts and tee nuts. These bolts stuck through the follr and the seats were "nutted" to them. The holes in the floor allowed water to get under the floor and rot it out.
Reel-Fun
I have a soft spot on the floor of my 89 Bayliner Capri bowrider i pulled up the carpet only and the ply wood is soft from water damage its not bad yet just barley soft.i dont think anything else is damaged but i will make sure do i jsut pull up the rotten wood replace and seal it? how would i go about it i also need to re wrap some seats where should i get the material for that? i will post pics when i get them up, thanks!
Kevin70
Hey Capt. Hook, Although these topics are related, you will get far more responses that are specific to your project if you start a new thread. There are a ton of people here that would love to help you out, but some people get upset when you hijack their thread.
