Parts for DPA-1
Skybreeze
I am after parts for the upper gear box on a DPA-1. Ineed a new sliding sleeve, gear set and a shaft. Anyone know where I can get these parts from.
Thanks
Skybreeze
Re: Parts for DPA-1
They don't list any parts for the DP-A. Nor do they show any schematics. Does anyone know if the parts from the later model i.e DP-E or DP-G are inter changeable with the DP-A
Don S
Re: Parts for DPA-1
Did you look it up under the engines model number as I suggested earlier?
Skybreeze
Re: Parts for DPA-1
Thanks for that. I found the schematics. You might be able to help me further. I'm after the sliding sleeve for the upper gear box but the part number 814601 is replaced with another but it dosen't give a new number. It just says multiple replacement. In the parts list it refers to a bulletin. Do you know where I can view that bulletin.
Don S
Re: Parts for DPA-1
Sorry, I thought I had that bulletin, but guess not. I know the sliding sleeve changed number, just don't remember if the shift shoe changed too. I would strongly suggest checking with a VP dealer to make sure you get the correct parts, or at least call marine parts express and ask them.
