Re: PB Recipes
A lot depends on the application and the type of boat. For fiberglass boats and repairs below the waterline, I'd recommend, 1 qt resin, 1 qt Cabosil, 1/4 cup 1/4" chopped milled fibers, mix to the consistency of Peanut Butter. Add more or less cabosil till you get it like you want it, add the appropriate amount of MEKP for 1 quart of resin. Stir well for 30 - 45 secs. 15-20 minutes working time depending on temps. If its HOT place it on ice in an ice chest to "Fool" the resin into thinking it's cold outside. Don't apply when temps are under 60? F. There are other fillers but...you don't want to use anything that could absorb water, especially if the repair is below the waterline.
