PC problems
steam_mill
I'm a computer consultant so I am very perplexed by the following problem:<br /><br />My dumb a$$ brother-in-law is getting divorced so he had to move into my house. My wife and I were away and he used my home computer.<br /><br />Of course he hit websites and installed crap he should not have. Norton did not catch it.<br /><br />Well my IExplorer now will only work if I have a webpage with a URL like this:<br /><br />c:\winnt\secure.html<br /><br />so I created this web page but every time I open up a new IE session, it must go to this web page before I can go anywhere else.<br /><br />Changing the home page setting has no effect. When I reboot the PC, it resets to the above URL.<br /><br />This setting has to be somehwere, but where?<br /><br />I've regedit etc. etc.<br /><br />Ideas?<br /><br />Tx.<br /><br />Joe
eurolarva
Re: PC problems
System restore from prior to when he used it. Should be in program files , accessories , system tools.<br /><br />If that works you might want to put a password on it so he cant use it in the future
Pikey2574
Re: PC problems
I had a similar problem and as eurolarva says the system restore should fix you problem that is what I was told to do and it fixed mine.
LubeDude
Re: PC problems
What the H**l is any one doing changing things on someone elses computer! The nerve, Youre right, he really is a dumb a*s, and disrespectfull too! There I said it!!
Homerr
Re: PC problems
First of all... Take your brother outside and beat him senseless... :mad: <br /><br />What operating system are you running?<br />If XP, then do as suggested. System restore to an earlier date.<br /><br />If W98, then I think you can simply do a re-install of IE. Not sure.<br /><br />Sounds like you got a re-direct Active-x program.<br />Can be nasty little things to get rid of.<br />Those are usually found on porn sites and those flash-type jokes or short movies.<br />A little box pops up and asks if you want to install and run 'xyz whatever', or 'do you want to set your homepage to...' and not thinking... you click yes. <br /><br />That happened to my daughter's computer. Messed IE all up. Luckily we had XP and system restore. Otherwise... CTRL/ALT/Delete and C:format ! :eek: <br /><br />If you run a decent ad and active-x blocker like Zone Alarm Pro, you won't have that problem. It stops them cold.<br /><br />H.
steam_mill
Re: PC problems
Sorry, I'm running Win 2k server. Tried all those things so far to no avail.<br /><br />Yeah, I know I could set up zone alarms etc. but the way I look at it I've never had a problem thus far because I don't ever install anything or go to those types of sites.<br /><br />I've never had viruses etc.<br /><br />My brother in-law is just a fool. I'm trying to avoid a complete re-install just because it is a royal PITA.<br /><br />Any other ideas?<br /><br />Tx.<br /><br />Joe
JB
Re: PC problems
Moving to Non-Boating Tech.
