pe water out
lt210
can a 1967 merc.500 50hp ser#1677271 be made to have a pe hole to be able to see water coming out of engin while moving ,the square hole in the back is to hard to see on a poonton boat eney ideas thanks jason
Mercury140-I6
Re: pe water out
Hello:<br /><br />If I'm not mistaken, your motor does have a pee-hole. It's twards the back on the left side (Looking at the back of the motor) under the handle and above the lower cowling. It's usually a hard little plastic tube that only sticks out 1/16th of an inch. Lots of times spiders like to plug it up with webs or wasps make a hone in there. Just get a wire about the thickness of a wire coat hanger or thinner and stick it up there (While running on the hose) and you should start to get water out of it.<br /><br />Craig
