brooksville_rebel
- Aug 12, 2011
- 240
1987 Mercury 3 cyl 70 hp OB engine. Getting it running and right on muffs. So far great on land
I noticed tho that it doesn't pee till about 2000 rpms or about, doesn't seem to be while idling. Once it does start to stream its a nice steady hard stream and stays cool to the touch. But noticed today that when getting the RPM's up there that the pee stream gets weaker, not stronger or staying the same. And then the water flow is hot.
Is that normal ?
Impeller need changed out ? Used engine so no clue if and when its been changed.
Would a water pressure gauge be worth it ? And were would it connect ?
Thanks
Mark
Is that normal ?
Thanks
Mark
