Peep Holes
castman27
Hi All
I was wondering if it is normal for water coming out of screw holes not much not skirting either, i notice that yesterday. Oh yes i have strip the top of the floor like the rubber mat that was there and all the bench etc... , did not removed no floor yet.
produceguy
Re: Peep Holes
No, this is not normal.
Your boat has issues my friend.
castman27
Re: Peep Holes
OK just cut a square about 6 inch by 4 inch in the floor there is water underneath, and also it as 3/4 plywood and there is 2inch of foam starting the inside panel going to the middle of the boat at 6 inch of foam. Can i used any kind of Foam or when re-doing the entire floor i dont put any??? Lucky a bit i am checking now need to rebuilt the floor before Juin 15 th 2011. The boat is a 14ft grew fiberglass the year i dont know.
Bob_VT
Re: Peep Holes
You can use 2" foam insulation board or 2 part foam available from many suppliers.....however, you need to find out if the water did any damage and how it got there. You might have more damage as you dig deeper. Go slow.
castman27
Re: Peep Holes
OK well will strip the rest tomorrow , but will put pics of the hole in 5 min
castman27
Look what i found with pics
This what i have found after looking at water coming out of screw hole, the foam is all soak, and i can see just from that square i cut that the wood as black spot on it , but now would any kind of foam will do the trick or it as to be floating foam , the boat looks like it as foam from one end to the other. Today i am removing the fiberglass on top of the wood and taking the plywood. I will post picks on the way .
castman27
Re: Look what i found with pics
I am sorry new to forum and tought you need to start a new thread, can i delete the other one??
And also i got new pics of what i did yesterday.
castman27
I have strip all the inside Help me plz
Hi ok now i am up at the stage and would need some help to how firstly is to remove transom i think this is where you attach the motor i guess. and also i wnat to know how to remove those beam.
Fisherball
Re: I have strip all the inside Help me plz
Search this forum for stringer, transom & deck replacement threads. Read them. You'll find more than you'll have time to read. Fun with Fiberglass!!
castman27
Thank You
castman27
You will find me dumb , but that is ok cause i try to lok for info on how to removed and re-install a transom with nosuccess , i know for sure there is alot of link in here. But it seems that i sniff to much of that fiberglass , lol, that i cant find some info.
castman27
Thanks for the links
castman27
Re: How to Glue the Transom
ok , now i am at the stage to glue the 2 piece for the transom together what od i use to do that , i got PL prenium glue would that be ok????
produceguy
That's what I used.
Some would lay resin on both sides that are to be joined together and 1 layer of 1.5 oz matt in between and then clamp together.
castman27
thanks , but witch one will hold better , do you think PL is better since it is wood compressing each other, but they say that with the resin etc.. will prevent water getting in between the ply. And i am using 5/8 outdoor wood should be ok with that i guess.
